Not sure what's going on here
  • 2
Varinabassing
Richmond,Va
Ok I have a pioneer 4100nex. When you cut the volume up on it the speakers go nuts like full volume static and popping noise. Can't figure out if it is radio or the amp. I can't balance left or right regardless position I still get music out of both sides. And randomly the music seems to get quite like some of the speakers are fading out or something. Grounded the wiring harness to the chassis. I have tried different rcas. I don't have another amp to try right now. I have change the ground on the amp. Any ideas ?
Couldn't hurt, but it's really dependant on the vehicle. My Wrangler had a ground strap that had to be attached to the Hu, if you didn't a bunch of wierd s**t would happen. Have you tried to unplug the rca's? If you have a 3.5mm to rca cord you can plug it into your phone and see if the noise is still there.
Sent from my Motorola 2950 Special Edition 3w.
It looks like you have the wrong connections. The head unit uses one amplifier to amplify 2 to 4 of your speakers. You are using 2 amplifiers...
5
I would have opt. for an Aero ported enclosure and a different mono amp for that sub, But ..thats me
5
That's a bit of a loaded question. A few FB amps were known to catch on fire. But that was more due to poor quality or specific use-scenarios...
20
3K
As title. Once i get to about 4/5 max volume my JL HD600/4 amp goes into protection mode on 2 channels, powering my mids. The other 2 channels...
Varinabassing
Varinabassing
Richmond,Va
The_Dealer
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
