Issues with 1ohm load
Sleezyk
So a while back I had a 1ohm stable mix amp that I wired to two alpine type a s subs. The ending load was 1 ohm but the amp acted like it was below and went into protect after a few min.
So now I have a 1200w Rockford fosgate prime amp, I have two 12" p3 subs that are dual 4 ohm voice coils... I got the positives and negatives connected to where each sub is 2ohm... Then I got them connected to the monoblock which connects the ++ and -- so that the final load is 1ohm.. I have looked over many wireing diagrams and am certain I have the wireing correct and have even verified it with a meter...
So why the hell da this amp also have issues? It goes into protect for a few seconds on big notes with volume high, and although I don't think is has went into thermal protect yet, it has gotten to 150f on one side of the amp where the mosfets are connected.
I have checked my grounds and made sure it is bare metal... I have added an extra cd power battery to make sure it gets what it needs..
So... Wtf?! Plz help
Voltage dropping too low
Put a dmm on the amp terminals and play a bass heavy song and watch your voltage plummet!!!
Wwwoooooooo low voltage protect
Be sure to see the sub specs. It should tell you the ideal sealed enclosure size.
673
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
Sleezyk
Sleezyk
Birmingham al
BoogerMan
