JD 1000 W6 or W7
  • 4
I have 1 W0 wired to my jd1000 right now. If I get 2 w3’s in a box do I have to change anything on the amp or can I just plug the W3 box in with no changes?
gotta reset the amp gain. heres how. the correct test tones are at the very bottom...
what all audio gear you using? what vehicle?
I’m using a jd1000 pushing 2 w3 10s in a box.
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
I just bought the stinger 1500. I watched a video on YouTube that there is an issue turning the gain all the way down using the amp, and you have...
  • Locked
Do you have any pics with user name and date or is this at a local garage sale?????????????????
The JD does ~800 watts@ 3 Ohms so I assume there would be no noticeable difference.
777
Carlos1son
CarAudio.com Regular
Carlos1son
old bridge NJ
Carlos1son
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
