Jensen Stereo distorts when motorcycle idles
  • 1
boblouder
I have a Jensen JMS2212 Marine Stereo on my 05 BMW K1200LT. The controller was installed up front on the gas tank and the amp/stereo is in my saddlebag. The Problem - when I ride the stereo sounds great. But when I stop at a light, the volume decreases and the radio breaks up. If I shut the engine off, the sound is fine. If I am stopped at a light with the engine running, it breaks up, but if I stand up and move forward, it clears up. I had the previous model installed prior and never had a problem. Although I had both the controller and the amp/stereo up front on the gas tank. Can anyone suggest ways to fix this problem. I prefer to leave the amp in the saddlebag. Thanks for any help.
No. Unfortunately, this seems to be a common issue with the Jensen Car1000. I have one that is less than a year old that gets stuck some days. I...
Not to deflate your ambitions, but here is a reference: https://www.simplyspeakers.com/Altec-6-x-9-3-Way-Auto-Speaker-Sold-Out_p_639.html Not...
Crutchfield is really good about that sort of thing. Not the cheapest prices but you know where your money went if you ever have any technical...
  • Locked
Nice crossover ..i have one it matches my Jensen BBE amps ....
9
File this one under “Who Would Have Thunk It?” The fuse to the solar array blew (for some reason). That was causing a dip in power to certain...
boblouder
boblouder
Eustis, FL
boblouder
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
