JL 300/2 too much for ID CTX65CS?
i know ID rates these at 100 watts RMS but has anyone ever run more than that with sucess?
I've talked to the guys at ID and they said that running them over 100wrms was perfectly fine. I'm planning on 165wx2 and they said that would be fine.
You will be fine with 150 watts of clean rms power, my buddy is running just over 150 watts to his CTX's and they show no signs of distress.
Even a one hundred watt amp can be clipped to 200 watts. No matter how big or small the amp if you don't know how to set gains properly, unless the amp is very tiny, you run a chance of blowing a speaker. At least with amp that can produce more power you wont' send it a clipped signal and you can get the most out of the speaker before it begins to distort. Gains for mids aren't hard. Set the hu at 3/4 or so turn up the gain on a track recorded very loud until it's either loud enough or you begin to hear distress. Unless you listen to music like an idiot that usually works well.
532
This Is a NIB amplifier, one of two that I was to use. Decided to go class A/B on the front mids and tweets and just purchased a Helix B FOUR...
Good thing its under warranty and that you have contacted A.Control about the issue so it has been documented. It will help speed up the return...
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
mjbailey21
Getting back into it!
mjbailey21
Dallas, Tx
mjbailey21
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
