JL bass knob for jd 1000/1
  • 2
Carlos1son
CarAudio.com Regular
Hello all,
I just got a jd1000/1 amp to power a 12 WO with a bass knob. I had it installed by a shop. It sounds great but I got a question. If I turn the bass knob all the way up will I damage anything? The gain on the amp was set at the shop about halfway. I have the knob dialed into the middle and it’s loud. Just wondering can I go louder safer with the knob all the way up?
id reset the gain like this (see link below), with the bass knob all the way up. the test tones are at the very bottom of the link too
I would assume they are pretty accurate as long as they are directly tied into the clip circuit on the amp. Having said that, the signal traveling...
11
722
I use bass knob all the time. Some songs it's almost all the way down. Some stuff, 80s music, it's all the way up. Different songs bass levels...
14
I used a 50k pot. A solder type potentiometer that I soldered panel mount RCA connectors to.
10
L & R signal guarantees you will not miss any program material in stereo recordings, which is the norm nowadays. It is also Double the Voltage as...
Carlos1son
Carlos1son
old bridge NJ
Carlos1son
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
