JL or Kicker?
has to be one of those? I would go with a Sundown SAX100.4 //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif best 4 channel ive had
Those JL amps don't overheat, even with 21 hour road trips blastin it!
I'd go with JL. Plus a whole lot of customization on the frequency responce!
kicker and jl amps are both great. Both reliable as hell, both put out rated power or more. The JL has the kicker beat on signal processing though. However, unless you're running active, it won't matter much.
MTX does have some good amps. I wouldn't mind playing with a couple of their bigger products.
However, if you're looking at mainstream brands and retail costs, you'll be spending way too much for what you'll get.
How much are you looking to spend? What will this amp be powering? There are TONS of great amps out there if you step away from the mainstream.
Thanks Hintzyboy. Looking to spend $300 on an amp give-or-take. Need to power 4 speakers, front doors - 6.5 comps, rear doors 6X8 for fill.
Thought the JL would be a great choice, the local shops of course want to sell their products, so looking for un-biased opinions.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
610
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Concep29
Concep29
Lake Havasu
WhoSayWho?
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
