Kenwood 2-ways. Top-Mount or Bottom-Mount?
  • 4
Got some Kenwood speakers in the rear which are bottom mounted. Working on the front doors which i knw are most likely gonna be top mounted. Wondering if top mounting or bottom mounting makes a difference on sound. If so i will change them 2 be top-mounted asap. Please gimme n e and all feedback on this issue. thanx.
well I like it to the bottom of the door not to far of the bottom kind of a half way almost in the center of the door. So it doesn't blearlying away on to your ears or to the floor of the back of the car. so you can feel it little more. are you making a new back door panels on your doors to go with these set of speakers?
im actually talking about screwing them in by dropping them in from the top of the hole or from up underneath. i have the screwed in from up underneath not dropped down from the top. does this matter as far as the sound?
I'd have to think that's gonna rattle, so yes.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
370
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
905
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
679
Heavymetal21
Heavymetal21
Sherman Oaks,CA
Louisiana_CRX
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
