Kenwood DDX512 iPod Question
prodgod
Bored
I just got my DDX512 installed and I am trying to connect my iPod Classic 80gb to it using the standard USB-to-iPod cable but I am having problems.
The only thing that happens when I connect it is the iPod says "Connected" on the screen, but when I go to the iPod source on the hu it says "Not Connected." Is there a setting on the hu that I need to change to make it work or could it be a firmware problem?
Any ideas?
Your white I-pod cable will not work on a video unit. You need a 300V or 301V cable to get an I-pod to work.
Yes, you do not have the proper iPod data cable for the Kenwood units.
They use a high speed cable to interface, so you would need the correct one w/video.
Call or email me if I can be of anymore help or you need the cable sent...
I am having a very similar problem with my ddx512 and kca-ip300v combo. When I plug in my ipod, the head unit reads disconnected and my ipod reads "do not disconnect" and has the red circle with the cross through it. When I plug my iphone in, I can manually play songs through my head unit, but my head unit still reads "disconnected" and has some static as it plays. I connected everything according to the manual (ddx512 and 300v) and have yet to see any results.
Any ideas?
Second, When I put a DVD into the head unit, I have no video but the audio does work. The screen is completely blue.
What can I do?
Thanks,
Justin
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
557
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
804
prodgod
Bored
prodgod
C-Town, WI
JSonger
    May 31, 2024
    May 24, 2024
