Kenwood DPX502BT Double Din not working!
  • 3
Nekolai
I just bought myself a new head unit for my car. I bought the Kenwood DPX502BT. I also bought myself a harness and a dash kit to make everything easy.... not exactly. First I had a problem with the harness not being pegged correctly then the dash kit was to small. So after I fix all that I got it all wired up. Last night my stereo was rockin. This morning it was working just fine as did last night. I get off of school and turn on my car to my stereo not even turning on! I have no idea what to do. All my fuses are fine and everything is wired correctly. Just a little FYI I bought this refurbished off Amazon from Sound of Tri-State Inc. (An authorized Dealer)
Pull it out and take it to an Audio shop,and let them bench test it with a diagnostic result page so that if its a faulty unit, you may be able to get it replaced under warranty....MAYBE?? Most shops may charge you $20 bucks or so.If it works fine, you may have a wiring issue.
Do you manage to solve this problem in the end? I have a similar situation now and I do not know what to do. I checked the audio system at the dealer and it turned out to be completely working. I can't return it, because I bought a used audio system and the warranty on it has already passed. I suspect that the problem lies in my car, so now I'm thinking about buying a diagnostic device in order to test my car with it. I decided that I should purchase https://thinkdiag.co.uk, since judging by the reviews, this is one of the best diagnostic tools on the market. I will be happy if someone shares a solution to this problem, thank you in advance!
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
227
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
647
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
558
First off, seems to me you have the specs backwards. Ignore peak, stick to RMS. Neither of them is going to do great at 60hz, that is really...
Nekolai
Nekolai
Misouri
Radiant
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
Latest topics
