SOLD Kenwood KAC-9104D
  • 1
ecko_0113
For sale is a Kenwood 9104D amp. The amp is in perfect working condition and is in great cosmetic shape. Asking 150 plus shipping.
The KAC-9104D Class D Mono Power amplifier cranks out mega doses of power in a much smaller chassis size (30% smaller than previous models), so it's more adaptable to tight spaces like under seats or in trunks. The KAC-9104D also has a Dual Mono Drive connection that allows you to strap two KAC-9104D amps together to power a single subwoofer—that’s 1800 Watts of power!
• 1800 Watts Maximum Output Power with 30% Smaller Chassis Size
• 500 watts RMS x 1 at 4 ohms (900 watts x 1 at 2 ohms)
• 1-ohm stable (output regulated to 900 Watts)
• Variable low-pass filter (50-200 Hz at -24 dB per octave)
• Bass Boost Control (0-18 dB at 40 Hz)
• Subsonic filter (15/25 Hz, 18 dB/octave)
• Class D design
• Speaker-level inputs with signal sensing turn-on
• Preamp-level inputs and outputs
• Fuse rating: 30A x 2
• 13-11/16"W x 2-3/8"H x 9-5/16"D
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
907
Bridging the amplifier Mono(LPF)on that sub will work just fine @4ohms
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
373
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
681
ecko_0113
ecko_0113
Fort Worth, TX
ecko_0113
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
