Kenwood x1200m or soundstream tx1.2000?????
  • 2
QueSound15
I know a thing or two....
Hi, I am getting ready to buy an amp and was trying to decide between the 2 in the title 1. Kenwood x1200m or 2. soundstream tx1.2000
I am going to be powering an AQ HDC3 15" D1, Im going to be wiring it up to a 2 ohm load.
the kenwood does 1200 rms at a 2 ohm load, while the soundstream does 1300 rms at 2 ohms. i like the features of the kenwood but i also like soundstream products. I know the kenwood would be great in SQ but i am wanting good spl with my sub.
any input will be appreciated! Thanks
The Kenwood is a good amp. I use one at 2 ohms.....seems to give rated power and runs cool. It is CEA 2006 as well.
One other question (hopefully someone with experience with this amp will chime in)......who has run the x1200m at one ohm and how much power did it produce? Kenwood website says it is one ohm stable, but I have seen posts online that it is not recommended.
This is something to think of incase you later want to add a sub....
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
370
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
905
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
679
QueSound15
QueSound15
Bloomington, IN
rebelliondog206
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
