Kicker comp r
Is it me or do anyone remember a couple years ago kicker had comp r 12s that was 800 watts rms a piece
Yes, but from what I've read, they had to change the rms to 500. Whether it was because people were smoking them out and warranty claims or what, not sure
If you punch it in google, bestbuy still has a link to them but when clicking on link it takes you to item no longer available.
Look at the search description for that same link and they have them spec'd for 800
Better subs out there anyways.
I got mine new in box, in a box for $50. I'm happy with it. I'm also nowhere near the caliber you guys are as far as knowledge or even the ability to tell the difference if I heard it, but for now it does what I ask.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
595
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
charleslatrelle
Nashville TN
Austin175
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
