Kicker CompR impedance switch?
  • 3
Paarthurnax
I recently bought two 12" Kicker CompR subwoofers, along with a Kicker CX 1200.1 Class D Monoblock amp.
Here's the link for the subs: CompR | KICKER
Here's the link for the amp: CX Amplifiers | KICKER
The subs themselves have an impedance switch on the bottom, which can be set to either 1 ohm or 4 ohms. I was just curious as to what you would recommend to set it to. I want the most bass I can get out of them, but I also didn't know if I set it to the wrong impedance if it might damage the sub/amp. Thank you!
Amp does full power at 2ohms and is not 1 ohm stable. So you will want a final impedance of 2ohms.
2 dual 4 ohm subwoofers wired in parallel will give you a 1ohm load. Series/parallel will give you a 4 ohm load.
2 dual 1 ohm subs wired series/parallel will give you a 1ohm load. Series will give you a 4ohm load.
You should have gotten D2 ohm subwoofers.
Return everything and start over with different amp and subs IMO.
The subs are both DVC 2 Ohm subs. So I figure if I wire both of their voice coils in parallel, which would be the 1 ohm setting on the switch, and then I wired the subs in series to the amp so it pushes them as a single 2 ohm load, it would work fine. Am I right?
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
526
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
Paarthurnax
Paarthurnax
Omaha, NE
Paarthurnax
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
