Kicker Hideaway, barely any sound coming out
  • 2
etboone
CarAudio.com Newbie
I have a Kicker Hideaway sub and I’m hooking it up to an aftermarket JVC headunit. The hideaway sub is powered and I had in in a previous vehicle. I wired everything up and am receiving almost no sound from it. When gain and boost are turned up all the way I can hear it somewhat with my ear up to it. Is there anything I can check or change on my stereo? I have the subwoofer included on the stereo along with the correct size selected. I’ve gone over all of the connections but cannot make it fully work. Its about 5% of what it can actually put out. Also i’m rather new to this, thank you in advance.
If you are 100% sure that it's hookup the same as it was in the other vehicle then it must be a head unit setting issue. Are you the one that hooked it up in the previous vehicle?
In the other vehicle I was not the one who set it up, but I do know that they didnt use rca cables to set it up
Is there a chance that theres a bad rca cable? The person hooking it up in the last vehicle couldnt get it to work with the rcas which is why he spliced into the speakers. Im using the same rca cable to wire it
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
595
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
etboone
CarAudio.com Newbie
etboone
etboone
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
