Kicker Key200.4 vs JBL DSP0486
  • 2
powerlifter405
CarAudio.com Exclusive
Another have a budget bullsh$t thread.:geek:
We all ran car and home audio for umpteen years without any DSP. My home subs are DSP'd by JTR but the rest of the system is run flat EQ.
I don't have to run a DSP but if it supposedly improves the SQ that much then I'm open to give it a shot.
I can score either of the amps above for nearly the same price.
The Kicker will do 4ch out and the JBL will do 8 out. I can take channels 7 and/or 8 and also use it as a sub out signal. If I get the JBL I'll use the extra channels to run the tweeters active, on the kicker I will need to use passive crossovers for the tweets.
any thoughts or experiences on these two? I do read the KK is basically plug and play, hit the test tone and thats about it.
I like the kicker honestly but I think the jbl with more outputs Is the way to go the dsp on the kicker kind of adjusts itself but one cool thing is it has a internal clip limiter
I found an open box kicker on Tues, delivered to my door for just under $200. If I don't like it I can sell it on the F150 forums and make my $$ back.
The neg reviews for the JBL was getting it tuned in. I'll post up my findings.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
599
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
powerlifter405
powerlifter405
Ur moms place
powerlifter405
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
