kicker L7 15" and 600rms
  • 1
Alexwaves
SPL NEWBIE
i have a 15" L7 and a kicker kx 1200.1 the sub is dvc 4 ohm so i am running at 2 ohm and 600 rms
i have it in a 4.5 cuft box and 40hz
i am doing 142.6 on TL closed up on dash but i am looking to get a few more db
the box is all square corners that in my next box i am gonna round out the port and corners.
but i am being told that if i do a box that is 2.5 cuft and 50 hz it will do very well ..
so far my car is peaking at 52 hz even with a different box with 6 tens
kicker does not rec a box this small
what do u all think
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
595
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
Alexwaves
SPL NEWBIE
Alexwaves
oshawa ONT (near toronto)
Alexwaves
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
