Kicker ZX750.1 (mono amp) with two 2-ohm Kicker subs (10CVT102) Can I make this work?
  • 2
I95SUXS
Hi, I've been doing a lot of research on this matter but I just want to verify. I have a picture attached of the set up someone posted on here for mono amps with 2 subs. What I'm wondering is if the set up (i.e. models I have) will work.
I have the kicker ZX750.1 mono amp (Link: Amazon.com: Kicker 11ZX7501 / ZX750.1 / ZX750.1 Mono Channel 750W ZX Series Amplifier: Electronics)
and two 2-ohm kicker 10CVT102 subs (Link: Amazon.com: Kicker 10 CVT10 2-Ohm 10" CompVT Subwoofer - 10CVT102: MP3 Players & Accessories).
Will making them into a parallel series create loss of power? My amp is rated at 933 RMS (which obviously it wont use that high of an amount...but I'd like to get a good 200 or so for each sub...they are also both rated at 400 peak..so 200 should be okay..maybe even up to 300) Any info is appreciated!
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
894
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
I95SUXS
I95SUXS
Fairfax, VA
zelix
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
