Kindly asking for advice for audio setup for campervan.
  • 2
Lekkerweervandaag
CarAudio.com Newbie
Dear all,
I am trying to build a decent audio system for our campervan conversion (2008 Citroën Jumper (Relay I believe).
At first, I was hoping to install 6 speakers (L/R doors, all corners of the 'living area') - but I think that would be overkill. I'm looking for quality sound, not ear-smashing sound. So I think 4 speakers (2 door, 2 in the back) will do.
This is what I had in mind.
Door speakers:
I have read good reviews of this Eton speaker component set https://www.eton-gmbh.com/en/produc...geotcitroendodge-upgrade/product/ug-fiat-f22/ . Impedance 3 Ohm, 'music power' (= RMS??) -> 80 W. No mentioned recommended minimum amplifier power.
Back speakers:
And for the 2 speakers in the back, I was thinking of these https://www.rockfordfosgate-store.nl/rockford-fosgate-p1683. 65W RMS per speaker, 4Ohm impedance, recommended power range: 10-70 Watts RMS per channel.
Head Unit:
Since I want to replace the headunit anyways (to get Bluetooth, aux, and such). I have room only for single Din. I was hoping that a 4 channel car radio would suffice for the speakers mentioned above. Often it says: 4x50Watts. But rarely do I see RMS values.
For instance, this Pioneer: https://www.pioneer-car.eu/eur/products/deh-x7800dab/support. If you download the user manual, it says 'maximum power output: 50W x 4', and 'Continuous Power Output: 22W x 4'. Does the latter mean RMS power? If so, would that suffice for the speakers mentioned above? Or do you recommend another 1-Din headunit. Or is an external amplifier necessary?
Very grateful for any imput and recommendations! Kind greetings from The Netherlands.
Never heard of the Eton brand but if they're made in Europe they're probably of high quality. Rockford Fosgate is a pretty trustworthy brand overall so those are probably OK.
As far as will the head unit be "enough" power, that is very subjective. Most folks here would probably not be happy with just head unit power only but it may be enough for you. There is no rule that says you can't just try them off head unit only and then add a small amp later if you feel you need more.
I would not trust any of the power ratings on head units.
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
390
It also lowers the amps efficiency and raises the current draw.
5
536
i have a 15 already for the lows ita a little over kill for a crew cab but I like it and I was hoping it would sound better and louder than my old...
7
689
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
9
810
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
Lekkerweervandaag
CarAudio.com Newbie
Lekkerweervandaag
Netherlands
hispls
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
