KINETIK 16V BATTERIES Quantity of 10 each weigh roughly 58lbs boxed from 40245 KY
davidtemple
Caraudio Guru
HC 16V KINETIK 16V BATTERIES Quantity of 10
Lightly used - like new Only did 2 shows with them....
$135 each + shipping on you!
Dual post design for running at 12V or 16V
1600 Amps
62 AH
AGM Technology
Sealed, non-spillable design
Able to mount in any position
More plates for stronger energy density
Higher voltage under load
Superior heat & vibration resistance
Helping LOCAL friend sell items from his Setup.
Yes you can use these for just 12V , but if you want to connect the 16V side you need to have a second ALT that is rated to do 16V to run your amps and such only at 16V
your regular car/truck ALT or HO ALT will charge the batteries on 12V side to 14.44+ Volts
You can use only 1 alty and have a 16v system
I have a jeep grand cherokee that is controlled by pcm but I have a external voltage regulator . I just switched to cmax and when I went to turn...
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
384
How have you verified that your alternator is making that much current under real world operating conditions in your vehicle?
9
That would be close to 4000w rms give or take. I recommend a 75ah or larger AGM battery and a 240a or larger alternator. And you will need 2/0 or...
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
tangelo95
