COMPLETED LC2i - $60+Shipping
  • 1
Koltrain129
Price
$60
Condition (1 worst - 10 best)
9
Missouri
I no longer have the car I had this LC2i hooked up in. I got about of year worth of usage out of it and had no problems.
New LC2i model sells for about $90-110 online.
Product highlights:​
  • 2-channel active line output converter
  • designed to work with most factory systems
Inputs and outputs​
  • 2 speaker-level inputs with 400 watts RMS power handling
  • Main (full-range)and Bass (for subs) preamp-level outputs
  • level matching controls
  • subwoofer level control output (for optional wired remote)
  • AccuBASS circuitry restores bass signal
Other features​
  • signal-sensing turn on
  • 12-volt turn-on lead output
  • recommended fuse rating: 1 amp
  • dimensions: 6-1/2"W x 1-1/2"H x 3-1/4"D
Was Photo Included
  1. Yes
Okay so for the basics, No I do not have a factory amp, or any other amp installed. I only have the one amp to power my subwoofers. I have not...
7
640
Nope, Either or. If you own both, then it's a loss on one or the other less what you sell it for, right? The PAC is an easier install and that...
7
Will you post a picture if the LC2i as it is wired. How did you set the output gains of the LC2i? What is the max voltage gain input on the amplifier?
Koltrain129
Koltrain129
St. Louis
Koltrain129
slater
    May 2, 2024
slater
    May 2, 2024
Latest topics
