Leaking speaker terminals
  • 3
Prefab enclosure? Is it carpeted? I've sealed terminal cups to an enclosure using rope caulk and some glue around the terminals posts. They're the spring-loaded binding posts that lock down with a nut and split washer.
All that carpet will have to be ripped out and replaced. There is no other way around it to get it done properly. Seal both sides of the...
17
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
5
584
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
486
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
651
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
558
EnemyxXxGhost
Jacksonville, FL
EnemyxXxGhost
