Left speakers weird sound issue. Might be a quick fix?
  • 1
HariboSingh
10
Canada
So I upgraded my 2011 Mazda 3 (Non-Bose) door speakers with Pioneer TSG6845Rs. The issue is that only the front right and rear right sound fine, but the 2 left speakers have faded and have lost about 80% of their volume.
With the stock Mazda head unit, the issue started with the new speakers. I replaced the head unit with a JVC-KD-R980BTS and the issue still ensued. The weird part is when I connect my home theater amp to the speakers and pump the volume way up, they burst back to life! Then they play perfectly fine for a few weeks, but the same problem comes back, and the left side begins to slowly die out. Of course I could pump them up every few weeks, but that's just a nuisance //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif The sound is low and "fuzzy" like coil rub.
When I put the front window all the way down I hear the window tap and glide over the speakers. I have a feeling it has something to do with the electromagnetic properties of the door, or the mounting space of speaker, but that doesn't explain why the rear does it too.
Any pros that might know a solution? I've browsed many forums but never found a fix.
Sounds like you shorted the other channel so check you connections. Don't ask just look. Will solve your problem Every time. If you ever short out...
9
Some of it plays well, some not so well lol. New decaf going around of "Break the knob off!" I have been playing and like it.
8
The Deaf bonce unit are not mdbass, they are midrange drivers. They will play pretty loud from 150 up. I don't support the company right now as...
7
174
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
94
Ill also add that, its nice to have rear fill for passengers and for that surround sound affect, especially for an SUV or a 4 dr vehicle. If the...
38
HariboSingh
HariboSingh
Canada
HariboSingh
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
