Length of Speaker wire from sub to amp?
swollen_cu
hey guys i have a 500/1 powering 2 10w3v2 in a ported box and wanted to move my amp under my passenger seat so i can push my box all the way against my back seat. But my concern in about the length of the wire going from the subs to the amp.
From my passenger seat to my trunk is about 5-6 feet in wire. Would it be ok to run 5-6 feet of 14AWG speaker wire to the subs without having any problems?
Thanks in advanced.
Well, to make an accurate guess, what load are the speakers wired to? IE 1 ohm, 2 ohm, 30 ohm with 300'dbs?
they are at a 4ohm load.
I already finished the wiring today, but now i have a bad alternator whining noise. A couple of months ago, i had no alternator whine, and just before i decided to rerun the system, i got some alternator whine. AND NOW after i have rerun the sysytem, each amp having their own separate ground, i have a bad alternator whine. I sanded down the spots to bare metal where i put the grounds, and made sure that it was tight.
THe alternator whine only appears when i either accelerate about 3/4 throttle or get into passing gear to pass someone up on the road.
Here's my setup just incase anyone needs to know:
Kenwood Headunit
Audiobahn 4 Channel
JL 500/1
2 10w3v2
Optima Yellow top with 2/3 Big 3.
Dual 4 gauge running from the battery.
Rockford fosgate Twisted Pair RCAs.
I am going to get my alternator tested tomorrow to make sure that it is putting out enough volts to the system before i jump to coclusions about anything.
If the alternator is fine, then i will try to ground the headunit first. Also, going to try the ground looop insulators, or maybe even possibly relocating my grounds to a different spot...
It is preferable that you ground your amps and your HU to the same common ground. 90% of the time this will solve the alternator whine problem.
Here is a very good link you should check out that will help you isolate where the alternator whine is originating from (HU, amp, sound processor, etc.):
http://www.termpro.com/articles/noise.html
are you smoking crack? grounds for an amp are supposed to be as short as possible, less than 24 inches if you can, not run 15 feet up to the deck lolz.
well i have one amp under each seat, so i cant really run run a long ass ground to one of the amps. thats just too much wire. I thikn the problem was that i used a preexisting ground that was already on the car. IT was a bunch of 22awg wires bolted down with a 10mm bolt.
I think i am going to try and created a new ground spot tomorrowm and groudn my HU. I am going to follow the steps on the site you gave me and see how that works.
never really understood why people get all bent on this issue.
It's a simple matter of resistance and wire >= 4ga is roughly the same resistance as a car's chassis over the same length. The few tests I have seen claim the average chassis is equivalent to something between 1/0 and 4 ga.
It might be SLIGHTLY advantageous to run a short ground to the chassis, but if there are noise issues, and making the ground a few feet longer to ground to a certain spot fixes it, by all means fix the noise.
Resulting change in voltage drop will be in the hundredths of a volt at the worst.
I'd have the internal port end 7" away from the back wall and just roundover that corner. That back (rounded) wall should effectively extend the...
Dammned good speakers. Just pass up the CL series,and you will be pleased with CDT speakers. I still enjoy all mine. Polk MM series and Infinity...
4
565
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
480
I agree with every one above. OFC is much better. Copper is a much better conductor than aluminum.
6
646
swollen_cu
swollen_cu
New Orleans
n2audio
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
