Lights Dimming
  • 2
Tmuffs
Hey My lights have been dimming just whenever my car uses any extra electricity other then what it needs to run lol and you just see the volt gauge move pretty dramatically but never goes below 10 but anyway at first the batterry was ****** to begi with if i used any elctricity other then interior lights when the car wasnt running the battery would not have enough juice to start it so the battery wouldnt hold the charge got a new battery can use whatever power i want for like 30 minutes and still start the car so the battery is good but the lights still dim and whatnot and when the really low bass notes hit you see the gauge move so anyway cutting to the chase.....some people say install a capacitor, and some people say that it will just draw more power, and some people say get a second battery so just wanted to get some oppinions thanks.
do the big 3 if you havent done it yet (search it on here if youre not familiar)
and get a 2nd battery according to the power youre running
---------- Post added at 12:57 AM ---------- Previous post was at 12:57 AM ----------
BTW, knowing what kind of car and what your current system is helps with specifics A LOT
Turns out that the big 3 cables connected the ground had some rust on the surface, brushed them with a wire brush and now there is no dimming...
8
Came across these. Rechargable, so you don't need to wire anything in and have a OEM look. I don't know if they're reliable or anything, I just...
5
707
Big 3 will not help dimming. Big 3 helps get more power to your amp, which is the opposite of what you want to reduce dimming. Either add lifepo4...
6
563
Tmuffs
Tmuffs
Smithtown NY
Tmuffs
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
