local enclosure builder stockton (tracy) ca
  • 6
I would hit up argent audio for a quote. They are about an hour away from you in morgan hill. They also have a subforum on here.
Argent is in L A now. Im in the salinas area That box in your civic trunk may not be an easy one to build what year civic ? Just hit me back I'm only an hour or so south I could do the box or I can send you to the team shop
Depending on the year civic it may be ok, or it may be a pita. The over all height that will slide in through the trunk is the issue. I have a design for a civic on my other computer that will work, but you have to remove the trunk latch and all that in order to get it to slide in. The other option is to build it inside the car of course...in some cases that can be easier. lol
agree
thanks for responses. its an 2006 unfortunatly so the opening is tiny. im willing to remove the latch i tried doing that initially to get a prefab in. i may just sell and buy a 12 because i want to be able to take my box out every now and then. but id like to keep the 15. if i go sub up it could prob be done but i dont want to blow my trunk lid although i do have a layer of dynomat
Yea, I would think switching to a 12 would be a better solution for you at this time. A 15 is far to much hassle if you may need/want to have a removable enclosure.
Is that a car show? Wow. Too much ground loops. The magnetic field may interfere with frequencies going to the antenna. Or you just need a...
15
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
820
dride
dride
tracy, CA
pro-rabbit
