looking for amps
  • 3
ga pawn man
CarAudio.com Newbie
ga
I have a van running a 14volt system(when running operates at 16volts). I am looking for d class full range amps 1 ohm stable that will operate at 16volts. 3000 watts rms for running mid bass drivers. I will need 7 of them. anyone have any suggestions
I would not run the HD line up to 16 volts. I did run mine up to 15.4. The Bass line is good up to 17 volts. Tolerances can swing from .5 volts.
Alot of Sundown amps are 16 volt stable.
I need this for mid range speakers. I don't think the bassline will run mids
MD would be your best bet but the voltage tolerances can vary up to .5 volts.
I'm not too familiar with Soundigital amps but they might have 16 volt stable amps.
The new Sundown SFB amps are stable up to 16 volts from their specs. Should be able to Email them and see what the exact cutoff is.
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
Excellent choice on the SSA Evil's. :)
28
ga pawn man
CarAudio.com Newbie
ga pawn man
ga
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
