Looking for a new SQL driver
And big (diameter) coils seem to perform better at their BL limits (ie Dyn & Morel midbass drivers).
It was a few years ago but built two HT subs using these, each fed with a kilowatt plate amp, the low end output would raise the hair on your arms, make your heart skip a beat, pretty impressive.
The peerless sub has a winding width of 2.25”. Not accounting for top plate thickness, that’s 28.5mm of xmax mathematically calculated, with top plate thickness accounted for its probably around 20mm realistically mathematically.
I don't recall the particulars, but 3.5" top to bottom travel is the linear movement, before being affected or distorting. I'd have to find the articles that discuss it, but that is pretty well documented.
That is mechanical movement, not linear. The mathematical calculation is the best way, that is the coil still in the gap (some may add 10-15%). Mechanical movement is when it comes to damage (coil hitting the backplate). Many use this spec along with peak to peak to make a sub appear to have a lot of xmax. The data sheet that shows xmax at 10.4mm may be accurate depending on how thick the top plate is. Looking at the coil again, the 2.25” is the actual full length of coil, not the windings so that spec is probably accurate. The 10.4mm is also mentioned on partsexpress as well.
Correct, my bad. All I know is when watching that thing go, it MOVES like a mofo!
Xmax is only part of the puzzle, there is more to it for making a great sub. Bottoming that sucker out will take a lot of work. There are so many subs now poorly designed that it’s very easy to do. With the power handling that sub has you can plug it in the wall no problem 🤣
Grab one of these.
eBay if you're in a hurry.
I did two of these ported in a home theater build and they are pretty impressive drivers. 7.5" VC, 3500 watt SQL air pumps! THis is terrible recording where the mic obviously can't handle the output but it gives you an idea!
Don't let the xmax fool you. Read up on this driver, really pretty impressive all the way around.
Is it just me, or do those subs look like they are out of phase?
Currently owned Stereo Integrity SQL, Adire Brahma, and RF power T1. I’m looking for another good sound quality subwoofer to play with and came across ID Max, are the ID Max similar to the the SI SQL? I’m also looking at the W7 but not sure if the price tag is worth it. Any other brand suggestions would be great as well.
What type of enclosure are you trying to use? And are you doing a vehicle or house or maybe both?
Ive always like how the DC Level 3 subs sounded
I'm a big fan of DC woofers. Their small box size and nice motor strength means you can put a ton of cone area and motor force in a pretty small enclosure vs other similar nature or class woofers, and they just really seem to pump sound out nicely. Might need some big ports, though. You can do like 2 15's in 6-7 cubes with 7000-9000w with DC, at least with vehicles. I'd also like to try the SSA Evil woofers in home audio, due to those subs liking a large sealed and ported box. I think that might really be beneficial with home audio. I mean, the Fsc of the SSA Evils can be iirc like 35 hz with full power 3500w, that's a super low sealed resonance; I actually talked to SSA about this one time. You could make a stupid 4th order bandpass with those that would play subsonic.
  • Fs 25.1 Hz
  • Re 0.7 Ohms/coil | 1.6 Ohms/coil
  • Qms 7.41 | 7.64
  • Qes .59 | .59
  • Qts .54 | .54
  • Mms 552g
  • Cms .70mm/N | .70mm/N
  • Sd 1210cm^2 | 1210cm^2
  • Vas 144.1l | 144.1l
  • Spl 88.4 | 88.4
  • Bl 16.9 | 24.1
  • Xmax 33 / 33 mm
  • Wattage 3500wRMS
  • Displacement 0.27cuft
Better link, sorry:
1st is the 15 2nd is the 18
Sealed2.5 ft^34.5 ft^3
Sealed Optimal4.0 ft^36.25 ft^3
Ported3.25-4.25 ft^3 @ 29-33hz6.5-7.25 ft^3 @ 29-33hz
Ported Optimal4.25-5.5 ft^3 @ 29-33hz7.25-8.5 ft^3 @ 29-33hz
Sub Outside Diameter15.625” | 15.625”18.500” | 18.500”
Cut Inside Diameter14.125” | 14.125”16.750” | 16.750”
Mounting depth11.250” | 11.250”11.750” | 11.750”
Look at those sealed sizes! SUPER LOWS
You might also check these out, idk if this would be what you wanted, probably have to run specific type enclosures with this, like a t-line:
  • Fs 25.1 Hz
  • Qms 7.41 | 7.64
  • Qes .59 | .59
  • Qts .54 | .54
  • Mms 552g
  • Spl 88.4 | 88.4
  • Bl 16.9 | 24.1
  • Xmax 33 / 33 mm
  • Wattage 3500wRMS
Better link, sorry:
I just did a big slot port box for 2 of the SSA 18s in a guys extended cab pickup. 16 cubes after displacement tuned to 30 HZ. Had to take the door off to get it in. Both of the subs had recones done on them recently. He had tiny little amps in this video. I think he now has 2 4500 watt amps strapped. I need to get a new video from them.
Great bang for the Buck/ Have (2)2ks and a 150.4. great amps for the Coin Thus far.A little head room doesnt usually hurt...
5
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
It's a Volvo factory amp, so there's a custom wire harness between the head and amp.
6
901
Somchine13
Somchine13
St. Paul, MN
denim
vlusardi
    Apr 27, 2024
winkychevelle
    Apr 27, 2024
Latest topics
