looking to build a box for 2 RE SXX 12's feedback please!
  • 3
coolio3800
Re audio SXx 12" 1000W rms 4 ohm dvc
so i went on the website for the subs and found the box should be tuned to 33hz which i have no idea how to do (problem 1). the optimal space is 2.0 ft^3 per chamber. is that before or after displacement of the sub? (problem 2) the rough dimensions that i got for the box are 31.75W x 20H x 11.75 D. that was with a "golden rule tool". is there some calculator or something that can build me a virtual box? i know i need a spec box for these subs but it's a little over my head, any feedback or comments would be greatly appreciated.
You only have 3.3ft3 of available space after wood displacement but that is before sub(s)/port. In short, you do not have enough available space for two.
well im going to make a bigger box, i messed around with the dimensions and have about 4.1 ft^3 after port displacement. their optimal space is 2.0 ft^3 per so that should work right? to avoid the sub displacement i'll just do a reverse mount or increase the box size just a bit
For sub, I recommend going true infinite baffle. You get to keep just about all of your trunk space AND sound great doing it (if you do it right.)...
7
I'm in the same boat and have a few posts on several forums so this is NOT advice but just sharing what's going through my mind and we can help...
10
4K
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
Excellent choice on the SSA Evil's. :)
28
coolio3800
coolio3800
Keller, Texas, United States
coolio3800
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
