Loose face plate causing stereo to turn off?
  • 3
B WeeZy
29
wis
Sup guys, i have a recent problem. I have a Pinoeer stereo for my car(not certain on model # right now, at school, will edit later)
But the face plate seems just a tad loose. Sometimes when i change the song, volume, settings, or anything it will shut off. I think its because of the face plate losing connection to the stereo. I tried cleaning the connectors with alcohol. That work'd for about a day. Now it's happening again.
I'd appreciate some help, thanks!
Only thing I could think of is wedge some folded up paper behind the opposite side the connections are on so it will lean down on em and not wiggle when you press buttons, or something like that.
Whoa, that will be one skinny port. The width of the back wall ports will be 1.08" wide (27.5mm), but the front port will be shared by 2 subs so...
5
942
Look at the JVC brand. I have an older unit with a removable face plate. Model KW-AV61BT. Contact Crutchfield.com support for some current...
Id play some of your favorite music.. play with the enclosure. Ive enjoyed subs up port up in a small suv(CRV). Subs rear port rear do nice as...
9
B WeeZy
B WeeZy
wis
Louisiana_CRX
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
