Manufacturer vs. WinISD recommended box size
  • 2
Simon96Taco
9
Canada
Last question - when deciding to go ahead an build the box, should I go with the recommended sizes that WinISD gives me, or should I go with the manufacturer's (Pioneer) recommendations? They are quite different.
For example:
The Pioneer spec page for this sub recommends 0.9ft^3 with a 3x13 port
WinISD Pro recommends 2.2ft^3 with a 4x20 port.
For sealed, Pioneer recommends 0.8ft^3
WinISD Pro recommends 1.07ft^3
Why are they SO different? especially the ported enclosure.
I would go with the manufac's specs...they are the right ones;) I dont know why they are so different, maybe it is because they based it on the average size box people use for the particular driver, but I doubt it....
- Steve
I saw a Kicker loaded sub box downward firing. It’s a sealed dial 8” sub. The description says 1 active and 1 passive sub. What’s a passive...
You have to know the signs for winisd. IMO, it really comes down to knowing what you’re doing. Some woofers don’t model well in winisd, at all.
It is a completley new truck except for what is painted red. It has a TCI custom chassis, four wheel disc, four corner adjustable coil overs ...
5
Here are the reasons of my assumptions and why I think there is little danger in this setup. 1. Bared conductors could cause a spark that leads...
38
4K
You need to accurately and carefully measure your trunk out, and decide how much space you want to use, too. Always measure your trunk out before...
12
Simon96Taco
Simon96Taco
Canada
ss3079
Latest topics
