Massive Audio Hippo12?!?
  • 6
I came across these a few weeks back but there is very little information on them or discussion online so Im working on selling my XFLs and I went ahead and picked up two of these I could only find dual 2s so it made my going half ohm choice easy ... These subs look just like a SQ hdc3 but have a lower Fs and 95db sensitivity? !? Idk about that
Here is what I found with a quick search, and man, they sure are proud of their stuff .... This particular description says it has a 2.5" vc's, but all the others I found say 3", which I would tend to think with a 500-2000rms power handling suggestion ....
Get that “Big Bottom” with the HIPPO Subwoofers When Massive Audio designed the “HIPPO” Series Subwoofers we had one thing we wanted out of the design. No junk for a trunk just a subwoofer with a “Big Bottom.” All three Hippo Series subwoofers 8”, 12” and 15” are truly giant works of art that can slam! These big bottomed boys use 3” over sized voice coils that hold 4000 Watts of power, extra deep diamond polished cast aluminum baskets, double stacked Strontium Magnets and Kevlar Fiber Reinforced Non-Pressed Paper Cones that has a industrial machined stitched edge right into the cone’s surround for added strength. To feed a 2013 HIPPO Massive Audio recommends 500 – 2000 RMS of raw power. You can cage a HIPPO in a sealed box as small as .375 cub. Ft for Hippo 8, 1 cub. Ft for the 12” and only 2 cub ft for the 15” or you can let them relax in a ported box for even more of that “Big Bottom ”. Massive Audio “HIPPO” Series is Big, Bad and Beautiful”.
FEATURES:
Heavy Duty, Rugged Industrial Textured Cast Aluminum Basket
High Energy Double Stack Strontium Magnet Structure
Dual Impedance Black Anodized 2.5” Voice Coil Former with Kevlar Spunlace
Kevlar Fiber Reinforced Non-Pressed Paper Cone with Industrial Textured Finish
Stitched Edge to the Cone’s Edge for Added Strength
Over Sized Mirror Image Dual Poly / Nomex Spiders
Black Anodized One Piece Pole-Plate for Added Motor Force
Heavy Duty Direct Input Wires Connection to Voice Coils
Reinforced Fiberglass Woven Dust cap for High Power Applications
Custom Tooled Rubber Gasket and Magnet Boot
SPECIFICATIONS:
Size 12"
Peak Watts 2000
RMS Watts 4000
Cone Non-Pressed Paper
Voice Coil 3" Dual 2 Ohm
Surround Tall and Narrow Foam
Magnet 320oz Strontium
Terminals Heavy Duty Direct Input Wires Connection
Basket Cast Aluminum
Tinsel Leads Heavy Duty Triple
X-Max 15mm peak to peak
SPL 95.99dB
Ported Box 14"H x 16"D x 20"W (Round Port 2 4" x 12")
Sealed Box 1.58 ft3
Yea their right inline with an hdc3 for price it seems like a good sub the company just needs to calm down on all the marketing hype because for these kind of subs and the people looking at them not to many will be fooled
Even at 279 theres no way id buy one over a hdc3 12
600 bucks??? They are 2 somethin on sonic
I only looked on their official site, 1 other site and an add for a used one @ $500 on CL ....
Both sites new listed them @ $600 ea ......
I did say a "QUICK" search ...lol ...
OP wanted info, I found info for him ....
Sorry if the pricing was off ....STILL, there are better options in the $250-$300 range ....
The lack of one way throw could be because of the hella tight gap it would take to keep the sensitivity that high. The only way to know for sure is to get a detailed review from one of our more experienced members.
  • Locked
hello mate, text me +1 (706) 300 5660 for quick response, if you need the Massive audio 15" dmx stage 2 for sale at a secondhand price, stay safe
3K
  • Locked
Hello all, I am new to this forum but have had no luck on ebay/gumtree/fbmarketplace regarding trying to shift my aftermarket car audio setup. My...
It only works if you send rca signal through it to your amps.
6
Now coming out to the wholesale distributor, Sub sonic car audio new brand owned by selelectronics since 2000. Look for new subs ,amp, empty...
AudioMan4Life
Ithaca,NY
AudioMan4Life
maylar
    Jun 2, 2024
Doxquzme
    Jun 1, 2024
