MB Quart Comp Crossover
  • 2
zinda
1 pair of QM 200.70 COMP passive crossovers
2 way crossovers with 3 tweeter settings and woofer crossover points of 3,600Hz 12db/oct 120watts/chan
these are brand new still wrapped in the original package only removed to take pictures of 1 of them, I had 2 sets but had to warranty 1 set and they sent me back the wrong colored board, mine were red these are blue. Was competing at the time so they were never installed. my red ones were ripped off.
$40 were over $120 new
I'm not sure if these are still sold but I'm sure that in some form they are designed for MB Quart speakers but will work on almost any good quality sets.
yes for most 2 way components or stealth series, I had the old 6.5 plastic baskets and the QM 19.02 NX tweets that came with that set. Box says; Designed for use with QM 130KX, 160KX, 215 and 218CX and Universal systems. When I upgraded to the larger 6 ohm tweets I went to active and sold the 4 midbass and had the 1 of these passive sets ripped off. Still have a pr of stealth mounts and a box of tweeters 4 & 6 ohms here somewhere.
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
3K
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
The Polks, the Kappas are great speakers and the Memphis units you have are good too. In your situation, keeping with the same dome material is...
9
626
Hi again, I appreciate all the suggestions and have my budget minded options down to 1 or 2 choices. I have noticed CDT, Image Dynamics and a...
12db is usually 180° out of phase if used left and right. 24db makes the full 360° phase change when running left and right. This is...
465
zinda
zinda
Phoenix, AZ
zinda
