**mb quart onx4.125**
it was bought brand new.....accidently put a 2 ohm load on it per side and it prolly blew..accidents arent covered...havent opened/broke seals to check internal
posting pics shortly.
Well you're ok then, It's rated for 2 ohms per channel, so u haven't void the warranty. I would just contact the place u purchased it from.
^^thats where i screwed up and misread the specs^^
i should been more specific earlier... **I ACCIDENTLY BRIDGED EACH SIDE DOWN TO 2 OHMS WHEN ITS ONLY 4 OHM STABLE BRIDGED**
What u did should not have blown the amp. Yes, it might have went into protect but it should have been as simple as shutting it down and turning back on. How was ur voltage when this went down? I am 99% sure this would be under warranty and that there was an issue with the amp prior to your lil mishap.
P.S I have seen this amp ran at 2ohm bridged and never go into protect. Me and a mate were comparing his amp (onx4.125) and my amp (1000c4) and both did operate in 2ohm bridged yes it gotta hella hot but they did not fail or go into protect.
X2
Have you tried operating it at a 4 ohm load, or 2 ohm per channel?
**** really?.......i guess its too late now tho since i already opened it....warranties voided //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
The Timpano amps are also small. I bought a small 1400 watt Timpano mono amp. I was impressed by the power I could get from it, but they have a...
15
Hello, I have bought a set of speakers but I want some recommendation of an amplifier that can work very well in them. 1 pair of RS1-216 1 pair of...
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
Potent Domain
Potent Domain
Boston, Ma
Potent Domain
