mdf or birch
particle board is pressed sawdust. MDF is an excellent box material as long as there's no moisture. As far as 1" MDF vs. 3/4" birch...there should be little to no price difference if you can even find 1" MDF. I can't find it around here
Particle board is pressed wood chips, mdf is sawdust.
You'll be fine using 3/4 mdf or birch, 1" mdf is great too but really heavy. Just brace and you're good to go.
no...chip board is pressed wood chips, particle board is sawdust, mdf is paper sheets. You are incorrect
Ok, particle board is sometimes sawdust but it is also sometimes pressed wood chips. Look it up. MDF is wood fibers mixed with a resin and wax. There, issue solved.
I like birch because MDF makes a crapload of dust that gets everywhere. And its heavy.
I'm willing to pay more for a more manageable, less messy product.
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
17 layers and it's worth it. Get the Russian stuff if you can. $206 per sheet in Vegas these days.
25
5K
rosszilla23
rosszilla23
chi-town
SpeedEuphoria
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
