MDF Speaker Spacers
  • 4
165mm (6-1/2") outside diameter
141mm (5-9/16") inside cutout diameter
screws are on a 155mm (6-1/16") diameter ring.
i want a new plunge router to mate up with my Jasper Jigs. But i've always made them with a simple jig saw. you just have to be steady and take your time. I can usually make a pair in about 30 minutes once everything is measured out.
i also recommend they be coated in resin before you drill out holes for t-nuts or hurricane nuts.
Thank you! Your replies are always so helpful. I will just do them myself with a simple jig saw.
As far as using t-nuts, are these just for mounting the speakers to the baffle, or should I also use them when mounting the baffle itself to the door?
Finally, what is a good type of resin to use? I assume this is simply for waterproofing?
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9
3K
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
266
infowarrior45
infowarrior45
St. Paul, MN
infowarrior45
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
