Memory Question
  • 3
No, because then the unit would be on all the time and you'd have to manually shut the unit off.
The memory (yellow) wire should be wired to a constant 12V source, as this allows the unit to retain all of it's stored settings such are radio presets, etc.
The power (red) wire needs to be wired to an iginition controlled source, so that it only receives power when the key is turned to ACC or On/Run, this way the unit will automatically turn on when the car is turned on (or to accessory), and turn off when the car is turned off.
So..yes, technically you "could" wire them both to a constant source....but it isn't the proper way to do it.
ok these are the wires that i have in the car, keep in mind the factory plug is gone so im connecting the cd player to the car with just the wires and crimps.
12v constant: blue/red
12v accessory: blue/black
ground: black/yellow
illumination: red/black
LF+: blue/orange
LF-: violet
RF+: white/violet
RF-: yellow/blue
LR+: green/orange
LR-: green/black
RR+: yellow
RR-: orange
which one should i connect the memory wire on the cd player to?
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
575
Nothing to add to this, Just wanted to say good luck and that I miss MiniDisc. OH!! Is that a Japanese Radio Tuner or does it get stations in the US?
862
That would be fantastic! Id love to see the skills involved here. It always intrigues me to see some customizing from small and detailed to large...
7
652
enforcer
boss
enforcer
Jacksonville, FLA
enforcer
SPLBassJunkie
    May 21, 2024
Mr FaceCaser
    May 20, 2024
