Mid bass and tweeter upgrade
  • 1
hemidreamer
CarAudio.com Newbie
Hi,
Vehicle: BMW 3ser E46 Coupe 2003
I'm complete rookie when it comes to car audio. I just got DD512 400w RMS sub and I'm about to replace it with my current Alpine sub ~250w RMS.
I already felt with Alpine sub that my mids and highs are a bit lacking. Vehicle probably still has stock factory speakers in. I'm looking towards upgrading mids and tweeters. Not going for anything fancy but just an upgrade.
First off I wanna upgrade my door speakers (2doors) mids and tweeters. I'm limited to 6,5"(16,5cm) and about 2" (5cm) depth for mid bass and 1"(2,54cm) diameter and 0,5"(1,27cm) depth for tweeters. I don't wanna start reconstructing my door and I wanna keep it looking stock externally.
So I found a set of component speakers: Rockford Fosgate P165-S that match my size limitations and are in my price range.
Since those speakers can handle 60W rms and my Alpine UTE-72BT head unit can produce 50W MAX(unknown rms) I'm thinking that those Rockfords are overkill and I will need a separate amp to power them?? OEM speakers are 2ohm rating and those are 4ohm. Should I look for something less powerful and cheaper instead if I don't want extra amp?
That was something I was going to try also to remove some of the gasjet from the front
12
Definitely hard to beat, but they're deep. Didn't know these were still floating around.
13
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
8
467
gain set well below "Normal" and base boost is off completely
15
hemidreamer
CarAudio.com Newbie
hemidreamer
hemidreamer
Chris Gerrish
    Apr 25, 2024
Chris Gerrish
    Apr 25, 2024
Latest topics
