Mid Cutting Out
  • 3
Decado
So for some reason today after having everything untouched for ~6 months my right mid decided to start cutting out. I noticed when I make a right turn it will go on but it will eventually cut back out. I checked every connection, RCAs at the HU are fine, RCAs at the amp are fine, speaker connection at the amp is fine, speaker connection at the speaker is fine, wires are fine. Now I've noticed if I switch the left and right speaker wire connection at the amp the side that cuts out changes so it has to be a problem with either the amp or the HU. What could be wrong, is there something loose in the amp or could it be the shitty pioneer pigtail RCA connection on the HU?
press on speaker,. if that makes it cut in and out, speaker is bad
The speaker isn't the problem, I switch the left and right speaker connections on the amp and the cutting out side switches.
Check the rca's...try another set to see if that helps . Or the amp might have a bad channel
Can RCA's just go bad without any damage to them? If the amp has a bad channel will it cut in and out like that?
I would check the rca first . Yeah they can go bad even if they look good
gain set well below "Normal" and base boost is off completely
15
The difference in 96 to 98 db is going to net you about an 22% difference in output, all things considered equal. When it comes to 325 per channel...
8
641
That was something I was going to try also to remove some of the gasjet from the front
12
Definitely hard to beat, but they're deep. Didn't know these were still floating around.
13
Decado
Decado
Minneapolis, MN
82 cutlass
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
