Midrange, Component, Coaxial
  • 2
a midrange speakers is a speaker who's frequency response is between 250Hz to 2000Hz. Most can play above that range.
a component is a speaker system that consists of a woofer and a tweeter separate. an external crossover to divide frequencies to each is included.
a coaxial is a speaker who's tweeter is rigidly fixed in the pole piece of the speaker (middle) and who's crossover in included, usually mounted on the woofer basket.
Yeah that chart is of good use and help. I have decent sub bass sound and higher freq as well. Just in between is moderately distorted and I want to improve the quality as a whole
Worth it? That depends on your thoughts. When I upgraded from 2 way to 3 way I was very happy, but when I did that I made pods and moved speaker...
8
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
10K
No, the $500 does not include the amp, I'll e-check em out. I appreciate it Do you have any specific recommendations? There is a lot of...
I know, generally speaking, that doing what you’re doing will give you some semblance of what the end result “should” be. That said, driver types...
7
JoshGuy
JoshGuy
Lawton, OK
JoshGuy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
