SOLD mint Polk C300.2 180 x 2 rms or 450+ x 1@ 4ohms
gentlejax
I am running all Pioneer old school so this needs new home
$130 shipped
ails:
· Class D circuitry
· frequency response 10-200 Hz
· 175 watts x 1 at 4 ohms
· 350 watts x 1 at 2 ohms
· requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
· MOSFET power supply
· module docking port with two-way active crossover (can be set for high- or low-pass at 60, 80, or 100 Hz, 24 dB/octave)
· preamp outputs can pass a full-range signal or be set for high- or low-pass at 60, 80, or 100 Hz, 24 dB/octave
· oversized power connectors
· remote gain controller
· 12-5/16"W x 3"H x 10-1/16"D
Im sorry but if you find the manual for the 300.2. Its wattages are rated at 13.8Volts. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I got a really good deal didn't I gentleJax
GentleJax, too bad my rockford P500-2 isn't working right now. Its a beast, man. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
okay, the dx350 makes 175 @ 4 ohms and the polk only makes 150@ 4 ohms @12vhttp://www.sonicelectronix.com/item_1255_Kicker+DX350.html
The 180w rating is at 14.4v
ok..I dont know what your deal is...cause your getting on my nerves...BUT
YOUR AMP is a single channel...........MY AMP is a 2 channel.....I dont know your amp but YOU said it makes .......175 x 1 @ 4ohms ......and YOU said MY AMP only makes 150 @ 4ohms or 180 @ 4ohms 14.4
THING is my amp BRIDGED MAKES MORE THAN YOUR AMP ...........BECAUSE ITS A 2 CHANNEL .....2 CHANNEL BRIDGED ITS RATED FOR 450
SO UNLESS YOU GOT SOME HIDDEN INFO STOP CLUTTERING UP MY THREAD WITH YOUR NONSENSE .....
gentlejax
gentlejax
Bossier City, La.
gentlejax
