SOLD mint Polk C300.2 180 x 2 rms or 450+ x 1@ 4ohms
gentlejax
I am running all Pioneer old school so this needs new home
$130 shipped
ails:
· Class D circuitry
· frequency response 10-200 Hz
· 175 watts x 1 at 4 ohms
· 350 watts x 1 at 2 ohms
· requires 8-gauge power and ground leads — wiring and hardware not included with amplifier
· MOSFET power supply
· module docking port with two-way active crossover (can be set for high- or low-pass at 60, 80, or 100 Hz, 24 dB/octave)
· preamp outputs can pass a full-range signal or be set for high- or low-pass at 60, 80, or 100 Hz, 24 dB/octave
· oversized power connectors
· remote gain controller
· 12-5/16"W x 3"H x 10-1/16"D
Im sorry but if you find the manual for the 300.2. Its wattages are rated at 13.8Volts. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif I got a really good deal didn't I gentleJax
GentleJax, too bad my rockford P500-2 isn't working right now. Its a beast, man. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
okay, the dx350 makes 175 @ 4 ohms and the polk only makes 150@ 4 ohms @12vhttp://www.sonicelectronix.com/item_1255_Kicker+DX350.html
The 180w rating is at 14.4v
ok..I dont know what your deal is...cause your getting on my nerves...BUT
YOUR AMP is a single channel...........MY AMP is a 2 channel.....I dont know your amp but YOU said it makes .......175 x 1 @ 4ohms ......and YOU said MY AMP only makes 150 @ 4ohms or 180 @ 4ohms 14.4
THING is my amp BRIDGED MAKES MORE THAN YOUR AMP ...........BECAUSE ITS A 2 CHANNEL .....2 CHANNEL BRIDGED ITS RATED FOR 450
SO UNLESS YOU GOT SOME HIDDEN INFO STOP CLUTTERING UP MY THREAD WITH YOUR NONSENSE .....
gentlejax
gentlejax
Bossier City, La.
gentlejax
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
