MMATS SRT/8 Charger
Looks cool, but I have aquestion about sound transfer into the interior. It looks like you only ported the outer 2 woofers into the cab. Did you install any kind of vent to allow bass in the trunk to transfer into the cab other than the vents?
I was just thinking the same thing.
all three are ported and i utilized the factory 8" woofer opening as venting.
it's very clean!.... but 7200?!?!? holy jesus! i hope he got more then 3 12's for that price
almost half of that was labor and materials. two sets of polyglas Focal components, two mmats amps, 3 subs, massive flatline, wiring, two batteries. these things add up quick!
nice suede work! **** isnt easy to mess with.. are you useing mobile solutions templates or makin your own?
made my own templates. keepin it custom //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have this one as well and it has been very useful. Would recommend if you need a versatile battery charger/small power supply.
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
dirtye30
dirtye30
buffalo
wone
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
