More Rattle Than Bass?
  • 4
angelo641
Ohio
I have a sundown sa-12 in a 2ft 35hz ported custom built box powered by a 1200w hifonics Zeus amp. Inside a 2000 Grand am. Lately I have been hearing the rear deck of the car, and platsics, Rattle more than I can hear the bass. The bass just doesn't fill the car like it used too. Usually it's like that in the cold weather so I always warm the car up so the rubber surround is less stiff, but nothing seems to be working. The sub moves fine doesn't seem blown, there's always been kind of a paper rattle sound when I turn up the volume, but Its not something you hear unless your right next to the sub. Could there be something wrong with the box? Or Sub? Maybe amp? There's no sound dampining material in the trunk or doors. Any help would be apreatiated. Thanks!
I have a sundown sa-12 in a 2ft 35hz ported custom built box powered by a 1200w hifonics Zeus amp. Inside a 2000 Grand am. Lately I have been hearing the rear deck of the car, and platsics, Rattle more than I can hear the bass. The bass just doesn't fill the car like it used too. Usually it's like that in the cold weather so I always warm the car up so the rubber surround is less stiff, but nothing seems to be working. The sub moves fine doesn't seem blown, there's always been kind of a paper rattle sound when I turn up the volume, but Its not something you hear unless your right next to the sub. Could there be something wrong with the box? Or Sub? Maybe amp? There's no sound dampining material in the trunk or doors. Any help would be appreciated. Thanks!
Eh, sound deadener on the back deck is a waste of money imo. Your plastic is rattling against other panel/the metal of the back deck. Just pull off the back deck, spray with spray on adhesive and put pillow stuffing in a light coat all over it, then put it all back together. Your essentially creating a soft quiet barrier between plastic and metal.
Check that your box isn't developing leaks and verify the sub is sealed tight to the box... that is if you've lost overall output. Others have answered how to reduce rattling trim pieces.
I have 2 more questions about the Kenwood DDX9907XR / DMX907S radios. 1. If I am listening to a source and have that particular source displayed...
Ill check it out. I was actually on the site last week. Thanks!
331
Well, get Two then and try to share for peeks sake!! :poop: :ROFLMAO::ROFLMAO::ROFLMAO:
16
881
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
485
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
660
angelo641
angelo641
Ohio
hispls
Doxquzme
    May 10, 2024
3toneEYZ
    May 10, 2024
