Most Bus From a raspberry Pi using PiMost
  • 1
Rhys_M
CarAudio.com Newbie
UK
I’ve been working on getting some kind of integration to the MOST bus on my jaguar XF and Land Rover Freelander 2, thought it might be of interest here
A but of back history, for a long time I’ve been trying to replace the factory head unit (3 years and counting project so far!) in that time I’ve moved between developing an app integrating canbus, to developing react-CarPlay to be able to run CarPlay on Linux based systems. Throughout the entire thing the MOST bus has been a massive blocker, no hardware or really projects out there that have tackled it, so finally a couple of months ago I set about it.
It started with a hacked up breadboard with a repurposed os8104 and MOST transceiver, then moved to a v1 of a custom PCB.
This one was very much experiment, but it worked, so I started writing the multi layer drivers for it (all written in nodeJs at this point)
Using the breakout header at the bottom I managed to get audio injection working using i2s from the pi. The beauty of this is it doesn’t use the awful clocks on the pi, but rather the clock source comes from the MOST network, running at 48khz on the jlr brand.
This then gave birth to v1.1
Which now has the header removed and traces run to the i2s GPIOs, it also has a can channel running too.
Currently implementing the standard fblocks for cd player, amfm tuner etc. Quick example video below of it integrating the OEM cd player
Marine speakers would be Ideal as stated and Coax. Polks would work very well. First choice of mine would be...
375
Zinc also conducts fairly well. I use zinc nuts and bolts on the terminal cups I build into my boxes.
5
729
654
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
537
I own a 2016 Lincoln MKT. I purchased a FORScan chip to increase the power handling of my aftermarket speakers. However, I'm having trouble...
Rhys_M
CarAudio.com Newbie
Rhys_M
UK
Rhys_M
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
