Most efficient enclosure
  • 3
K9Candyman
CarAudio.com Recruit
27
ITALY
Hi all. What is the most efficient box for music and demoing? No spl monotune and things like that, just loud loud music.
i have 4 Pride sv3 15s and 2 powerus 15000. 4th order vs 6th order vs normal ported? The goal is to shake cars around mine :D
I’d say a t-line or horn is most efficient, in wide-bandwidth sense.
With what you’re looking for, do a low-ish tuned ported box or series 6th order.
Are you able to wall the vehicle?
Yes Buck i can wall. Can you give me an example pic of your idea?
You could also do a clamshell-type ported.
Just depends on your vehicle. The most important part is making sure your subs fit with enough airspace. Doing big powered systems, the airspace can disappear quickly, even with the biggest b-pillar you can fit. It takes a good bit work to plan one out, correctly, if you go that route.
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
694
i didn’t get to hear it yet. He’s supposed to install it this weekend.
30
3K
K9Candyman
K9Candyman
ITALY
Jimi77
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
