Most under rated "2000w" amp.
Yeah, that was the other one I was considering.
Either the 20.1 or the RF.... hrm....
thanks for the help guys //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
well, if they are going by lowest rated ohm load, get one that is rated close to 2000 @1 ohm, but can do .5 ohm. just one that pop's up is the SAX-1500. will do 1500 @1, but if you have the electrical to back it up, it'll run .5. witch i belive puts it close to the 3k mark.
I'm assuming this is for street stock?
IMO the BEST is a pair of rockford t10001 or the 20001. But many other brands will do the do. Autotek has a underrated 1000d that you could run in a pair. Also sundowns 2000d that will be out soon quoted from SMD "We also clamped the 2000d. With a 1.1ohm reactive load (rising from 0.5ohm nomial) it made 2500-2600watts. Starting voltage was 14.0v dropping to 12.7v."
Not for street stock.. like I said, a smaller local org.
Good to know about the Sundown... I'm a big fan of Jacobs so I may go that route JUST to give him some business. (even if it's not #1 in the power department) //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I have two old school US 100HC's built on the 2000x boards instead of the 1000x board like earlier model they will probably do close to 3000 each at 1ohm....they are rated 100x2 or 50x2 at 4ohms I don't remember //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Jordy, the old MOJO 2kw, when modded will do insane power at 0.25. Pretty prone to blow up, but I don't think you are going to get more power.
Pretty prone to blow up is bad //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
This is for the "rookie" class and you have to play music....
Wanna lend me one for a while? :p
Hahaha.... man, it's pretty funny to see someone say "ewww' to having a system that can actually PLAY music!! //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
HAHA. I figured this was burp only when you mentioned competition. Dang sure wouldn't try it on music though. LOL
i like your style. os cheaters ftw.//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
I guess they were slightly under rated....at least not like the Orion Concept rated at 1w ...lol or was it .5 //content.invisioncic.com/y282845/emoticons/confused.gif.e820e0216602db4765798ac39d28caa9.gif
Oh come on! Why'd you have to go and tell me the price? Now I'ma start eyeballing them.
When you random through your music library, you know you got your gear dialed in nicely.
18
https://www.alpine-usa.com/products/subwoofers/truck-enclosures
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
JordyO
JordyO
Ottawa, ON
skateboardkid
    May 18, 2024
    May 18, 2024
