Moyea MKV Converter, Convert MKV to PS3 readable format maintaining MKV subtitles
  • 1
One of my dear friends recently met a big issue about how to convert MKV files to MP4 or Xvid format viewable on her PS3. She tried mkv2vob which can convert MKV to M2TS with subtitles, but the output quality is not perfect; she would rather choose another alternative tool converting MKV to H.264 MP4 or Xvid with subtitles in an easier way. Luckily I just used this kind of program called Moyea MKV Converter which is designed to convert MKV to any other popular video and audio format with subtitles.
If you just get the same issue about converting MKV to H.264 MP4, Xvid, or other media formats on your media players or portable devices, the following step-by-step guide may be of help for you.
Preparation: Free download Moyea MKV Converter here, install and run it.
Step 1: Add MKV files into this program
Step 2: Set output format and location
After all the MKV files are loaded, this program allows you to select the output format from the drop-down list “Format” for example PS3 format MP4. If you want to save the output files into a specified path you like, you can set the destination folder from the “Output”. Otherwise, the generated files will be saved in the default path automatically.
If the MKV files include subtitle which contains more than one language as well as audio track, this program allows you to convert MKV to H.264 MP4 with subtitles.
Step 3: Convert
Once all the settings are done, you can click the “Convert” button to start converting. For its multi-thread encoding technology, the whole conversion task will be finished in a little time.
Now, the new version of Moyea MKV Converter supports converting MKV to DV, Wii. In other words, as for those DV, Wii lovers this program is also helpful for you.
  • Locked
Well I think mounting depth with be shorter on the BM 11, and of course surface area is more on the MKV 12. The 11 is more of a niche driver than...
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording...
Some manufactures actually cut out some of the low end to prevent speaker damage to the factory speakers. I would consider trying one of these for...
  • Locked
Cerwin Vega IOEM8 8ch line converter for sale, bought brand new as A-stock last summer. Mounted to baffle in preparation for installation but...
zsvrsn3
Banned
zsvrsn3
3636 Gateway Center, San Diego, Canada
zsvrsn3
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
