Does a Line Output Converter need to be wired up to both sides of the car for a sub?
  • 3
Ha, I grew up in La Mesa, GO BOLTS!
The simple answer is no, you don’t have to. The better answer is YES, it is preferable to sum both channels to one so that you don’t miss out on differences in recorded material from either channel. By taking signal from both R/L your amp then sums them together (MONO) and you get everything intended from the program material.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording engineers to use panning to create a soundstage which results in information in left or right channels. Choosing one means you will miss out on the information in the other channel. You also get the bonus of summing two signals which is free signal gain. Always, without exception*, use both left and right channels to feed a sub amp.
*some may say that there can be noise or cancellation issues when using two channels in rare instances but that is from improper install/wiring or damaged equipment and something that should be fixed with proper wiring methods, instead of a band-aid of using one of the two channels.
Most new radios have that feature. Just check that they have 4 RCA outputs. Those are line output. If it only has 2 RCA outputs, make sure they...
Speaker ratings are generally a thermal/mechanical limitation of the drivers. Music is dynamic, not continuous. During quiet periods a song, you...
4
157
Thanks everyone for the replies! Like I said in my first post I’m not wanting to be loud, I just would like to have a little extra bass.. I like...
12
839
It's always leaned that direction. Not sure how cheap you can really get anything done these days. Deadening and custom mounting...
10
859
You're not going to know until you test with a meter. Typically even carpeting a box as opposed to painting is going to lose a few tenths.
AudioArchitech
CarAudio.com Newbie
AudioArchitech
San Diego
keep_hope_alive
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
