Multiple terminals on subs
you could put 2 amps 2 one sub if they were identicle amps. but it is to give you more wiring options ans higher power potential
Using DVC over SVC is simply for wiring flexibility. It's not 'easier', per se, and in fact is more confusing for most people, but I think flexibility would be the more accurate term.
If you're trying to decide between a 2 ohm SVC and a 4 ohm DVC, odds are, it isn't going to make a **** bit of difference. Certainly not one you'd ever notice.
Do not use two amps on a single sub unless you are very experienced and know exactly what you're doing.
In other words, judging by your post, this is not something to attempt.
more wiring options
adding more subs & whatnot.. looks like you have alot of reading to do..
if you know what subs you want you need to find an amp to power them ..
you need to get the correct VC setup so your setup will work proper..
>>Wiring chart
You should read this..lots of info here..
http://www.bcae1.com/
keep reading any & all info on this site.. its one of the better Car Audio sites..
peace troy
DVC SVC? dual voice coil. single voice coil. So I can wire the amp to one terminal and be alright?
no. you cant. youll put stress on one of the voice coils. like what he said about sparks plugs, also like boxing with one good arm and one broken arm.
To add the tv, I got a second deep cycle battery, ran thick cable from my starter battery to the deep cycle battery(or you can run to a dc to dc...
6
The amps are not fused themselves. I am considering using smaller gauge wire for the 200 and 300 watt amps (I believe they only recommend 12 awg...
Ok ill just do the two ohm for now .i have really good electrical .ill prolly just go ahead and buy a bass 8 or 12 k for now until i can get a...
4
I have a 2012 Ford F150 Platinum Crew Cab. I was saying that since my secondary battery would be grounded to the frame could I not ground my amps...
4
<v=rus>
<v=rus>
Eau
shortyg83
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
